x
mattiofhell
mattiofhell Posts: 2
edited July 2023 in Personal Cloud Storage
x
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    As I know, to change domain name, you can still set up DDNS by configuring your router.
    Enable DDNS on the WAN interface of your router (you can find free ddns to use them) and configure the necessary port forwarding rules to forward traffic from the WAN to the LAN IP address of your NAS. Once this is done, you can access your NAS using your domain name and the specific port number you configured for the port forwarding rule.
  • and for edit login page?
  • okimarukas
    okimarukas Posts: 92 image  Ally Member
    You can change the server name on the NAS, the NAS326 model uses the server name as the login page url in the local network, go to Control Panel > System > Severe name. You can change the server name there.
  • vamara
    vamara Posts: 1
    The startup schedule doesn't work, I've set up a one-shot ignition and nothing happens. Why does this happen?
