LTE5398-M904 - Switching between internal and external antennas
BruCom
BruCom Posts: 32 image  Freshman Member
edited January 2024 in Mobile Broadband
Good morning community
As far as you know, because of the hadware switch, is there any risk swithching between internal and external antennas when the device is turned on ?
I had a search thru the user manaul but did not find any recommendation.
Thank you
  • Friday
    Friday Posts: 114 image  Ally Member
    Hi @BruCom,
    from my point of view, the switch button can work both when device is on and off.
    Just to insure to connect external antennas when switching to EXT port !
