GS1900-8HP PoE Issue
ok, already done - RMA created.Zyxel_Melen said:Hi @ZyxelHamburg2023,
Based on your feedback, your GS1900-8HP has PoE failure. Please check here to submit RMA request.0 -
I Have experienced exactly the same issue, switch working perfectly and then the lates 2.70 firmware has caused the PoE to fail
I just did this firmware upgrade (2.70 v3) on my switch that has been running fine for YEARS and this update broke my PoE! It was working fine just minutes ago, did the upgrade, now I get the error POE INIT FAIL.
Please pull this firmware ASAP!
Hi @matm347,
Welcome to the Zyxel community!
Is your previous firmware V2.70(Axxx.0)? If yes, please help to upgrade to V2.70(Axxx.5). We have fixed the PoE failure issue due to upgrading firmware from V2.70(Axxx.0). For more information, please reference below Release note:
Zyxel Melen0 -
Tom, you're a hero! Simplest fix ever, though Zyxels service is really great (big shoutout for them!) and I received my replacement today- this is a really nice and easy way to repair this device. Thanks for sharing.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
