Zyxel LTE5398-M904 and STUN server
Hello community
is there any of you that knows if the above modem can use a STUN server ?
I had a look to the user manual and found nothing but I'm not an expert and could this feature goes under another name.
In addition, in the configuration back up file, I saw there are parameters to connect to a STUN server but the WEB interface does not show any. Could it be that such parameters are enabled only when a specific option is selected or are applicable ony to other models other then the LTE5398-M904 ?
Thank you
Hi @BruCom
Session Traversal Utilities for NAT (STUN) is designed so that VoIP will work through firewalls and with private IP addresses and NAT.
https://www.3cx.com/pbx/what-is-a-stun-server/#:~:text=A%20STUN%20(Session%20Traversal%20of,outside%20of%20the%20local%20network. has some information for example.
I have used STUN through another Zyxel device in my home set-up in order to get VoIP working, because my phone is on a private IP address inside my local area network.
If your VoIP provider runs a STUN server, then it will likely work though LTE5398-m904 as long as your 4G provider will also pass it through.
I downloaded the user guide for LTE5398-M904 from Zyxel's Swiss distributor at https://www.studerus.ch/de/support/downloadcenter/ by searching for it, and it mentions a set-up of an outbound proxy being possible so that you don't have to use STUN or SIP ALG, see below.
I hope that this helps.
Kind regards,
Tony
Hi @BruCom
Kind regards,
Tony
Hi @tonygibbs16
Thank you very much for your reply.
I think that my VoIP provider runs a STUN server since, back in March, he provided me the parameters to connect my device to the server together to other suggestions to keep a stable SIP connection.
Another suggestion from the VoIP provider was to turn on the "keep alive" function.I went thru the device manual and did not find a way to connect to a STUN server or a "keep alive" function.
This is the reason why I opened this tread asking support to the community.
Anyway, me too I found that page in the user manual and I turned of the SIP ALG, changed the "SIP Register Expiration Duration" to 120 seconds and the "SIP Register Fail Re-try Timer" to 900 seconds.
This from some time and I must say that the SIP registration is a lot much stable now.
So, yes, seems that it works though LTE5398-M904 and 4G provider also pass it through.Thank you again for you explanation and support.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
