LTE5398-M904 - Wan Backup
bepperino
Good morning everyone.
I bought LTE5398-M904 router (router A) and am using it with mobile sim with unlimited data
I also have another router (router B ) with another mobile sim, again with unlimited data.
My intention is to use router B as a backup line to router A.
Doable?
Can you give me a hand on how to manage everything through the Broadband_WAN Backup feature?
Thank you
Hi @bepperino ,
In the userguide I found there's the WAN backup feature, but it's used for the wired WAN connections, and you have to set Ethernet WAN>State enabled.
The usage of making alternative routers as a backup line is not able to achieve per the userguide instruction.
thank you!
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
