NR7101 remote management
JeanMarc
JeanMarc Posts: 1 image  Freshman Member
edited January 2024 in Mobile Broadband
Hello. I need activating remote management on NR7101. As I don't have a fixed ip address, my first step was to set up dynamic dns (using zoneedit.org); Big surprise : the given dynamic address is on private range 10.x.x.x.  How can I obtain the correct public address of my NZ7101 ? Regards. Jim.
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi Jim,
    In order to access your NR7101, are you able to access the NR7101 by the gateway IP address from the browser?
    In the following example, try to access http://10.173.244.242 or https://10.173.244.242 see if that works.
    C:\Users\ZT01990-04>ipconfig
    Windows IP Configuration
    Ethernet adapter :
    Connection-specific DNS Suffix . : home
    IPv4 Address. . . . . . . . . . . : 10.173.244.241
    Subnet Mask . . . . . . . . . . . : 255.255.255.252
    Default Gateway . . . . . . . . . : 10.173.244.242
    In terms of getting the correct public IP address, please take a screenshot of the System Info page and identify which IP address you want to get on your LAN-side client.
