NR7101 most current firmware
n_o
n_o Posts: 66  Ally Member
edited January 2024 in Mobile Broadband
V1.00(ABUV.8)b2_E0
Modul FW: RG502QEAACR13A02M4G_ZYXEL
seen on A1 branded device ( came via OTA )
R13 line modem firmware is coming
  • SELBERG
    SELBERG Posts: 373  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    ISP:s use their own firmwares, got nothing to do with Zyxels own.
  • SELBERG
    Not sure when but somethings is on the way soner or later, probaly later
  • JeanFrancois
    JeanFrancois Posts: 45  Freshman Member
    First Answer First Comment Friend Collector First Anniversary
    https://support.zyxel.eu/hc/en-us/articles/4403365084818
  • monstrmprz
    monstrmprz Posts: 37  Freshman Member
    edited April 2023
    Modul fw is RG502QEAACR13A02M4G_ZYXEL? 🤔
    I hope this is not the buggy version that the Mikrotik 5G routers with the RG502Q modems received, because the NR7101 has the same Quectel RG502Q-EA…
    https://forum.mikrotik.com/viewtopic.php?t=189075#p960286
    And there has been no fix since October 2022. 🙄
    "No news, but there's a definite Quectel fault, and they are blaming Qualcomm for changing the baseline."😀
    By the way, is R13 only better in that it has a new baseline and supports 5G CA? Compared to the R11. I saw on a forum that the RG502Q-EA is not sure it supports 5G CA.
