password set to none - now can't access the router
I've set the router with "no password" setting. When I tried to log in next, it still required a password, which obviously there isn't any set, so I'm a bit confused how can one log in then… I thought if I set the password to none, it would just open the router if I type 192.168.1.1 in the browser… or what is the "no password" setup and how can I go around it? Just don't tell me to reset the router as I've just set the maximum amount of website blockers on and not keen to start it all over again (by the way, why there is a limit on the number of websites that can be manually blocked?).
Thanks, Matt
"Just don't tell me to reset the router "
I afriad this is the only way to recover it now.
"why there is a limit on the number of websites that can be manually blocked?"
Every device has its capability for each function, and receviced a fixed storage for each functions.
For example, if the device received 4KB in storage for blocked website, so only certain number of websites can be set.
Hi @Zyxel_Melen,
DX3301-T0
ps: I tried 1234, admin and whatever other default password I could think of. Also tried the last password I set before what I thought was removing the password requirement… but no luck. I guess it will have to be set back to the factory reset…
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
