password set to none - now can't access the router
Matt229
Matt229 Posts: 3
edited January 2024 in Mobile Broadband
I've set the router with "no password" setting. When I tried to log in next, it still required a password, which obviously there isn't any set, so I'm a bit confused how can one log in then… I thought if I set the password to none, it would just open the router if I type 192.168.1.1 in the browser… or what is the "no password" setup and how can I go around it? Just don't tell me to reset the router as I've just set the maximum amount of website blockers on and not keen to start it all over again (by the way, why there is a limit on the number of websites that can be manually blocked?).
Thanks, Matt
  • SEJ
    SEJ Posts: 112 image  Ally Member
    "Just don't tell me to reset the router "
    I afriad this is the only way to recover it now.
    "why there is a limit on the number of websites that can be manually blocked?"
    Every device has its capability for each function, and receviced a fixed storage for each functions.
    For example, if the device received 4KB in storage for blocked website, so only certain number of websites can be set.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,047 image  Zyxel Employee
    Hi @Matt229,
    Welcome to the Zyxel community!
    May I know what your model is?
    Zyxel Melen
  • Matt229
    Matt229 Posts: 3
    Hi @Zyxel_Melen,
    DX3301-T0
  • Matt229
    Matt229 Posts: 3
    ps: I tried 1234, admin and whatever other default password I could think of. Also tried the last password I set before what I thought was removing the password requirement… but no luck. I guess it will have to be set back to the factory reset…
  • SEJ
