How do i log in into recently bought router?
![IDNXY](https://us.v-cdn.net/6029482/uploads/defaultavatar/nN4PAQRO7TCNP.jpg)
![First Comment](https://us.v-cdn.net/6029482/uploads/badges/MBNFIRD87YVH.png)
Also i dont really know where to put this as im kind of new to this forum but i thought this might be security related so ill give it a try.
I recently got my hands on an Zyxel EX3301-TO router and i set it up as normal in the instructions. Later that same day i went to try to access the Admin panel on the router but it refused to let me inside.
I did check multiple times that i was using the correct admin panel login but it still refused me entry. I have not found any other similar cases yet so im asking here.
Please help.
Does your Zyxel router connect with ISP LAN directly?
Maybe you can try to reset to factory default:
1.Unplug your WAN port —>2. press the reset button over 10 seconds —→3.reset to factory default.
The router itself works very good its simply the admin panel i can't access. I'll try factory defaulting it today.
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
