NR5101 vs NR5101 Nebula
Tuva
Hello, I am looking for a 4G & 5G router for my home, and can choose between NR5101 vs NR5101 Nebula which are available for the same price. What is the difference, and why should I choose one over the other?
Nebula is just a centralised web console for configuring and monitor multiple devices over multiple locations, etc. For a home device, I'd personally say you do not need it. You'd just manage the device via the normal built-in interface on the Router. Thanks.
shall I skip the Nebula framework?
How do you disable nebula web console and only use router interface?
I use NR7101 non Nebula version but i have Nebula firmware installed.
I just untick Nebula, see pic.
I don´t know if it looks like this in NR5101 interface….
2 -
So @selberg you confirm that I can install Nebula firmware on a non Nebula NR7101? Is there any particoular step to follow?
Thank you!
- 603 USG FLEX H Series
- 481 News and Release
