NBG7510 - how can I add a static route? The Routing sub-menu is missing in ABZY.3
I am setting up my NBG7510 and have updated it to V1.00(ABZY.3)C0 ok.
I am using my Zyxel DSL home gateway to get to the Internet successfully, so I have not configured any Broadband settings in the NBG7510.
The WAN port is connected to a LAN port on my Zyxel DSL home gateway and has come up as shown below.
However, I cannot find how to add a static route. The Routing sub menu is not showing, see below.
How can I get the Routing sub menu to show please?
Kind regards,
Tony
Hi @Zyxel_Jerry
I think that I have found a configuration issue as the root of my problem.
I found that if I added a Trust Domain for 192.168.1.0/24 into the NBG7510 and enabled Ping, HTTP and HTTPS for WAN under Remote Management, then I could Ping successfully the NBG7510 on 192.168.123.1 and could login to the web console from a host on 192.168.1.0/24 subnet.
The routing was already present, but the configuration for Remote Management wasn't because I have the NBG7510 WAN port connected to a LAN port on my Zyxel DSL home gateway.
So configuration issue for me. My issue is now solved.
Kind regards,
Tony
Hi @tonygibbs16
There was an error with the UserGuide information, and we will make the corrections.1 -
Thanks @Zyxel_Jerry for your reply.
Does this mean that there is not a way to add static routes in the NBG7510?
Kind regards,
Tony
Hi @tonygibbs16
We currently do not have a plan for this feature.1 -
I think that this is an omission for a router.
I have raised it as a Consumer Idea.
Kind regards,
Tony
Hi @Zyxel_Jerry
Kind regards,
Tony
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
