XGS2210-28HP Stacking
Good afternoon
I have 2 XGS2210-28HP switches and I want to stack. The manual does not indicate whether it is possible to stack the specified switches in a ring (2 pairs of cables between each switch, i.e. SW1 ports 27, 28 are connected to ports 27, 28 of SW2).
It needs to be clarified:
- is it possible and correct to connect 2 switches with a pair of cables as in the photo;
- Will there be an increase in the exchange rate?
Hi @Smartqwerty,
This is unnormal, could you change the connecting DAC cable from port 27 to 28 and port 28 to 27? This is used to check if the problem is on the DAC cable or the switch port.
Zyxel Melen0
Hi @Smartqwerty,
Yes, you can connect in a ring.
But the exchange rate won't be increased since ports 27/28 are different stacking channels. When both ports are connected, one will be the main channel, and the other be the backup channel.
Zyxel Melen1 -
Good afternoon!
Thanks for the answer!When connected by a ring, the topology in the stacking menu in the switch interface is still indicated as a chain, not a ring. This is fine?
Sorry, I'll post the question again:
Hi @Smartqwerty,
Zyxel Melen0 -
Now works fine, thanks a lot!
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
