LTE5398-M904 Connection & WiFi problems
I have a strange problem with my LTE5398-M904.
For example when I have several devices connected on WiFi (2 smartphone, 1 tablet and 1 imac) if I download something from any device the others will be disconnected from WiFi and after a few minutes LTE connection is not avaiable anymore (but all lights on the router are green) and I have to reboot the router to have LTE connection working again. I have this issue on both WiFi 2,4ghz and 5ghz.
I am on firmware V1.00(ABQV.2)C0 and LTE Module EG18EAPAR01A08M4G
I have tried my sim card on other LTE routers (huawei, tplink and mikrotik) and everything is working well. I also tried to reset to default settings but I have always the same problem.
Can anyone help me please?
last lte module firmware here
-2 -
Hello @Nykos
I think that you are on the newest firmware available, according to https://www.zyxel.com/global/en/support/download?model=lte5398-m904
You could contact support using the form if you still have the issue, see https://www.zyxel.com/global/en/form/contact-support
If you have some logs then they could be useful.
Kind regards,
Tony
Try updating the modem firmware. Description in my post:
https://community.zyxel.com/en/discussion/16882/lte5398-m904-lte-module-upgrade#latest0 -
Hello @Nykos
May I ask you which mobile operator do you use ?
I think to have the same problem, LTE connection established but suddenly no internet access from any device but I never thought to link this behaviour to WiFi but, rather, to the operator because, to me, the problem occurs only with a specific one.
May I suggest you to try the IPv4+v6 trick (see cellular WAN & APN settings, doesn't matter if no IPv6 address is assigned as long as the router tries to get one when IPv4 is renewed). There are at least 3 threads dealing with this issue in this forum. And no fix from Zyxel after several months 🤡
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
