Device temperature has exceeded system threshold
My USG-500 keeps shutting down.
I get the message that the device temperature has exceeded threshold.
the router is managed via nebula:
Router# debug hardware fan-get
Sensor[0]:75 degree
Sensor[1]:50 degree
Sensor[2]:57 degree
FAN[0]:6914 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
what can i do?
Best Answers
on the wall.
Not sure on the threshold on my Flex200 I get
Sensor[0]:73 degree
Sensor[1]:43 degree
Sensor[2]:47 degree
FAN[0]:0 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
which is idle no fanYou might have a heatsink loose?
That box on the top of the USG might be blocking vents?
I moved it and it is still overheating.
Sensor[0]:72 degree
Sensor[1]:48 degree
Sensor[2]:54 degree
FAN[0]:6878 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
Router#0
Where have you put the the USG-500?
on the wall.
What is the threshold of the router? There is lots of other equipment with no issue.
Sensor[0]:73 degree
Sensor[1]:43 degree
Sensor[2]:47 degree
FAN[0]:0 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
Hi @LDI ,
The device will dump warning message if sensor exceed 80 °C.
The ventilation holes of FLEX500 are located on both sides, It is recommended to remove the appliance above away to ensure proper ventilation.
Thank you
Can you add fans to the Flex500?
With zip ties its possible you could get something like this
to blow air I from then bottom
Sensor[0]:72 degree
Sensor[1]:48 degree
Sensor[2]:54 degree
FAN[0]:6878 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
Router#0 -
Sensor[0]:72 degree
Sensor[1]:48 degree
Sensor[2]:54 degree
FAN[0]:6878 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
Router#0 -
@Zyxel_Kevin In my life i NEVER put in that orientation a Zyxel Firewall. Only "plane", on feets or on rack.
Is that positioning supported/advised?
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
