Anti-Malware False-positive or Real?
hi, I have updated the signature but the problem still persist with other king of file. I send you my screenshot.
thank you.
I have the same, ATP100:
warn anti-virus FILE DESTROY
Virus infected SSI:N Type:Anti-Malware Signature Virus:Gen.Variant.MSILHeracles.da651960 File:AD2F1837.HPPrinterControl_145.1.1083.0_neutral_~_v10z8vjag6ke6. Protocol:HTTP
I have uninstalled the HP update for printers and the problem ends
No matter how many time trying to update, Tread intelligence MAchine Learning remain very much outdated…. 2017…
Same for me
hi to all the problem seems to be solved after the saturday signature update.
regards.
I've tryed again to update signature, but I still have the problem.
Attaching: signature update, signature release, firmware release and log.
Now it's too much day with this problem!
Please solve
Luca
Dear all users,
We are currently investigating the problem. Please add the File Pattern "AD2F1837.HPPrinterControl*" on the Allow list in your Anti-Malware settings:
Here is the on-premise firewall setting:
Here is the Nebula firewall setting:
We will provide an update as soon as we have more progress. Thank you for your patience.
once you've provided fix it would be better to remove this exclusion?
Just to keep trace about the settings (300 firewall to manage!)
Luca
I agree with LucaPapaleo, I think it would be better to delete the whitelist entry after your fix. Please confirm.
Hi @LucaPapaleo and @KS1983
Many thanks for your update. Currently, we are fixing it now. Adding the issued file pattern to the allow list should be a temporary workaround solution, so you can add this file pattern on the site that has this false positive detection and maybe won't add it to every managed firewall. Really appreciate your patience so far. Thanks.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
