NCC scheduling SSID
Hey,
I have a nwa50ax AP, using NCC and want to set up a schedule to enable wifi for certain time periods. I found this article
but I can't find the settings in my NCC.
I find the configure settings, where are WiFi SSID and AP settings but I can't find it anywhere. Can someone help me scheduling WLAN?
Hello @henne
The reason why you cannot see SSID availability is because the Advanced mode has not been turned on yet. To enable Advanced mode, please go to Configure > WiFi SSID settings and toggle the option as shown in the screenshot below.
Once you have turned on Advanced mode, you will be able to see SSID availability on the menu tree.
I hope this helps.
Best regards,
Nami
Nami
Hello @henne
I hope this helps.
Best regards,
Nami
Nami
Hi Nami,
thanks a lot. That was the trick. I have activated the advanced mode several times before but was just looking in the WiFi SSID settings and disabled it again. I did not expect that it also affects other settings as well.
Best reards, henne
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
