Broadband menu on EX3301-T0
Jasson
Jasson Posts: 4 image  Freshman Member
I am trying to set up external access for a server plugged into the broadband of the router. I believe to do this I need to set up upnp and several port fowarding. While reading the manual it says to access the broadband menu from network setting. For me, it is not there.
how can I get it back? in the end I want ports to connect with out indirect connection happening. Plex server and Tableau Server
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Jasson
    It sounds like you have customised firmware from digi, as the version has G0 on the end in place of C0.
    Maybe digi can help you…
    Kind regards,
    Tony
