NWA210AX Console Port
Hi @Pook ,
In case your USB TTL cable is the cable with four pins including one pin with a triangle icon, please connect the USB TTL cable to NWA201AX by console cable’s pin with a triangle in the place of the NWA210AX console pin with a triangle icon (pin 1).
In case, your USB TTL cable is as below image, please follow Zyxel’s console header pin definition: pin1 NA (with the triangle mark), pin2 White (RX), pin3 Green (TX), pin4 Black (GND). PS: Don’t connect red color pin to zyxel’s console pin.
By the way, could you share with us the symptom when your AP went down?
Be a Community MVP: Win a VIP Deal Dash on Your Next Zyxel Purchase!
Thanks Judy
We are observing the below…
1.Slow Blinking Amber/Green on status LED
2. Slow blinking Amber Ethernet port LED in Sync with Status LED.
3. Appliance not obtaining any IP address so not accessible via web console.
4. Several Device resets performed.
I got the terminal working now, I have the cable that has separate pins so thanks for the pin out. Can you give me any CLI commands that can be run? Appliance looks to be booting ok at least.
Hi @Pook ,
Please refer to this CLI reference, some console port notes are at the page 22.
By the way, we suggest checking the router's DHCP server settings to allow the AP to obtain an IP address.
Does this look normal?…
Starting boot runlevel
Starting default runlevel
Start EnterpriseWLAN system daemon....
. WIFI FW mount is successful
ln: ./firmware_rdp_feature.ini: Read-only file system
12064+0 records in
12064+0 records out
12064 bytes (11.8KB) copied, 0.052310 seconds, 225.2KB/s
131072+0 records in
131072+0 records out
131072 bytes (128.0KB) copied, 0.495192 seconds, 258.5KB/s
cat: can't open '/lib/wifi/wifi_nss_olnum': No such file or directory
starting cnssdaemon
initiating cold boot calibration****
cnssdaemon pid=3268****
No Direct-Attach chipsets found.
Applying system configuration file, please wait...
.......................................EnterpriseWLAN system is configured succe
ssfully with startup-config.conf
netopeer-server start
Welcome to NWA210AX
Username:0 -
Hi @Pook ,
The logs are normal when the AP is booting. Have you had any other issue with the AP?
Hi Judy
I am going to raise an RMA, the device just does not show on the LAN at all.
Hi @Pook ,
In you case, slow blinking amber/green on status LED means the AP not obtaining IP address actually.
You can try to use ZON to scan and set the static IP for AP. This link shows you how to configure Zyxel device basic setting.
And then, please access to the AP by the username/ password as admin/ 1234 to collect the diagnostic file. We'll support to check when receiving your file.
Or you also provide us the Teamviewer/ Any Desk remote session on the laptop that connects to the AP via console cable. We'd like to do troubleshooting.
- 393 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 906 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
