ISP WAN Settings Changed
DaveP_Ire
DaveP_Ire Posts: 1 image  Freshman Member
I recently switched ISP where the WAN settings differ from the previous ISP. The switchover happened without being notified to when this would happen so I can no longer access my USG20-VPN through Nebula or locally. Are there any methods to update the WAN settings? Or if a factory reset is needed, can I restore all other current settings minus the old WAN settings?
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    You should be able to grant Local lan GUI 192.168.X.X even you lost Nebula access.
    Trying to change WAN IP by local GUI.
Nebula Tips & Tricks
