Firmware update file for old device
Ian_L
Ian_L Posts: 4 image  Freshman Member
Hi!
I'm in charge of maintaining some older products in my network - one of them is the Zyxel Prestige 2302R (model number: 401342)
I noticed I can't find older products' firmwares anymore - I'd like some help with getting the most recent firmware :)
Thank you!
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Ian_L,
    Greetings.
    Since this model was EOL, can you let us know the current version of your FW?
    Thanks.
    Ivan
  • Ian_L
    the firmware version is V3.60(AOQ.0)V0
  • Zyxel_Ivan
    Dear @Ian_L,
    The V3.60(AOQ.0)V0 is the latest version of this model.
    There's no other fw later than this version😃
    Thanks.
    Ivan
  • Ian_L
    Hi Ivan!
    You're right, but from Google searches it seems like the latest firmware (the one you sent) is from Nov. 2005, and the one I have is from July that year. So if possible I'd like to make sure everything is as up to date as it can be until we deprecate it
    I also have a few more boxes that I'll need to deploy and for sure some of them are dusty enough to probably feature even older versions :)
    I'd appreciate the help
    Thanks!
    Ian
  • Zyxel_Ivan
    Dear @Ian_L,
    I've attached the FW for download.
    Please feel free to reach us with further questions.
    Thanks.
    Ivan
  • Ian_L
    Hi Ivan!
    I am sorry, I have the P-2302R model (without the P1C). Is that the same firmware?
    Thanks!
    Ian
  • Zyxel_Ivan
    Dear @Ian_L,
    Greetings.
    We appreciate your inquiry regarding technical support for your model. However, we regret to inform you that the model P-2302R-P1C has reached its End-of-Life (EOL) status. As a result, we are unable to provide any further technical support for this particular model.
    Upon reviewing our database, we found that the firmware for P-2302R-P1C is the only file we have.
    We understand that this may cause inconvenience. If you require assistance with a different model or have any other questions, please do not hesitate to let us know. We are here to help.
    Thanks for your understanding.
    Ivan
Service & License Help Center
