Backwards compatible between models PLA6457 and PLA5456?
PLA5215 and PLA5456?Accepted Solution
Hello @NicoZ
Welcome to the forum.
PLA6457 supports the ITU-T G.hn standard, whereas PLA5456 supports HomePlug AV2.
They both use 128-bit AES encryption.
and talk about the difference between G.hn and Homeplug AV2.
Since G.hn includes HomePlug AV2 as I understand it, then the two devices PLA5456 and PLA5456 will likely be compatible with each other.
I hope that this is helpful.
Kind regards,
Tony
Hello @NicoZ
Kind regards,
Tony
Many thanks Tony!
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
