Nebula Control Center Version: 17.00 (build 230517.0522, prod - Navigation Panel Menus
ivessm
ivessm Posts: 45 image  Freshman Member
How to get the Navigation Panel Menus to fully display?
The help says to: Click the arrow ( « ) on the upper right corner of the navigation panel to collapse or expand the navigation panel menus.
But there are no ( « ) to click on.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    edited May 2023
    Hi @ivessm ,
    Thank you for your feedback.
    As NCC 17.00's spec, there is currently no arrow available to collapse or expand the navigation panel menus.
    We acknowledge the inconsistent issue between NCC 17.00 UI and Help document. We will discuss it internally and provide updates here.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @ivessm ,
    We will correct the problem in NCC Help documentation.
    Once again, thank you for your feedback!
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
