Can't install SMB V2 on NSA325v2
Hello everyone,
i tried to update samba on my Zyxel NSA325v2 according to this HOW TO https://zyxel.diskstation.eu/forum/viewtopic.php?t=24&sid=3e40a8ef0b230af1ad6c9d0802170f46
It fails at the Point where i start /opt/etc/init.d/S09ZyXELSambaReplacement.
An error accured: mw: can`t rename '/opt/var/lock/*': No such file or directory
Can anyone help me?
Best Regards
  • Mijzelf
    Mijzelf Posts: 2,635  Guru Member
    First Anniversary 10 Comments Friend Collector First Answer
    That is caused by next lines in the start script:
        # Move /opt/var/lock to ramdrive, else the maintenance of browse.dat will keep the disk awake
    if [ ! -h /opt/var/lock ]
    then
    mv /opt/var/lock/* /var/lock/
    rmdir /opt/var/lock && ln -s /var/lock /opt/var/lock
    fi
    Apparently you don't have an /opt/var/lock directory, so you can just create the symlink
  • derboum
    derboum Posts: 5
    Thank you for the quick answer.
    Unfortunetly after i did the command
    and then tried to start
    /opt/etc/init.d/S09ZyXELSambaReplacement start
    nothing happens.
    What can i do?
  • Mijzelf
    Try restart instead of start. Or reboot the box.
  • derboum
    derboum Posts: 5
    Tried both. Nothing happens.
    Anything else i can do?
  • Mijzelf
    Use the 'debug mode' of the startscript:
    /bin/sh -x /opt/etc/init.d/S09ZyXELSambaReplacement start
  • derboum
    derboum Posts: 5
    edited May 2023
    Is this good or bad?
    I tried to check smbstatus but it throws an error.
  • derboum
    derboum Posts: 5
    ~ # /bin/sh -x /opt/etc/init.d/S09ZyXELSambaReplacement start
    • prgmname1=/opt/sbin/nmbd
    • prgmname2=/opt/sbin/smbd
    • configfile=/opt/etc/samba/ZyXELSambaReplacement.conf
    • nmbdpid=/opt/var/run/nmbd-ZyXELSambaReplacement.conf.pid
    • smbdpid=/opt/var/run/smbd-ZyXELSambaReplacement.conf.pid
    • basename /opt/etc/init.d/S09ZyXELSambaReplacement
    • [ S09ZyXELSambaReplacement = samba.sh ]
    • startreplacement
    • [ -f /etc/init.d/samba.replaced.sh ]
    • return
    • exit
    this is the output.
  • Mijzelf
    return
    Are you sure that it isn't automatically started on boot? The start procedure is roughly
    • Stop stock firmware (/etc/init.d/samba.sh stop)
    • Rename firmware startscript to /etc/init.d/samba.replaced.sh
    • Create a symlink /etc/init.d/samba.sh to /opt/etc/init.d/S09ZyXELSambaReplacement
    • Start the Entware samba via this symlink (/etc/init.d/samba.sh start)
    The symlink is created because the firmware uses it to restart samba when needed. This way the firmware restarts the Entware samba without knowing (or needing to know)
    Stopping of the replacement is the same sequence reversed.
    The script checks if the renamed startscript is available, and if so, then exits, which seems to be the case.
