Error showing data usage and application usage in Nebula app Android using SCR50AXE
Hi @Klaus_S_K,
Which firmware version is your SCR running? If it is not V1.00(ACGN.2), please help to upgrade to this latest firmware. It has fixed some traffic-accurate problems.
Here's the release note:
If the problem still occurs when running V1.00(ACGN.2), please help to enable Zyxel support for me to check.
The Zyxel support path is Help (On the top right) > Support Request > Zyxel support Access to enable and save.Zyxel Melen0 -
For the moment i have traffic mangement disabled. I just enabled it again, so we can check data comparison in 24 hours from now. I will get back tomorrow with an update. Have enabled suppport access for you
Hi
Same problem today, also on the nebula webpage:
Hi @Klaus_S_K,
Thanks for your feedback and the privilege.
May I know if the latest screenshot is from the client "Lukas PC"?
In the meanwhile, I will help to check with our engineer to find out what might cause this problem.
Additionally, we might need your help to provide a remote PC to access SCR50AXE. I will send the request and detailed information to you by private message.
Zyxel Melen0 -
The client name is Sony TV
Regards
Hi
Have to disable traffic management for now, because my boys have to much lag playing online, and i can not get them added to passtrough the app filter.
Im still available for help and remote access if needed
Regards
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 318 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
