Error showing data usage and application usage in Nebula app Android using SCR50AXE
Klaus_S_K
Klaus_S_K Posts: 10  Freshman Member
Hi
Looks like there is some kind of error with the usage data
Lots of application data, but almost no usage data?
Is that correct or is it an error?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @Klaus_S_K,
    Which firmware version is your SCR running? If it is not V1.00(ACGN.2), please help to upgrade to this latest firmware. It has fixed some traffic-accurate problems.
    Here's the release note:
    If the problem still occurs when running V1.00(ACGN.2), please help to enable Zyxel support for me to check.
    The Zyxel support path is Help (On the top right) > Support Request > Zyxel support Access to enable and save.
    Zyxel Melen
  • Klaus_S_K
    For the moment i have traffic mangement disabled. I just enabled it again, so we can check data comparison in 24 hours from now. I will get back tomorrow with an update. Have enabled suppport access for you
  • Klaus_S_K
    Hi
    Same problem today, also on the nebula webpage:
  • Zyxel_Melen
    Hi @Klaus_S_K,
    Thanks for your feedback and the privilege.
    May I know if the latest screenshot is from the client "Lukas PC"?
    In the meanwhile, I will help to check with our engineer to find out what might cause this problem.
    Additionally, we might need your help to provide a remote PC to access SCR50AXE. I will send the request and detailed information to you by private message.
    Zyxel Melen
  • Klaus_S_K
    The client name is Sony TV
    Regards
  • Klaus_S_K
    Hi
    Have to disable traffic management for now, because my boys have to much lag playing online, and i can not get them added to passtrough the app filter.
    Im still available for help and remote access if needed
    Regards
Nebula Tips & Tricks
