Error showing data usage and application usage in Nebula app Android using SCR50AXE
Klaus_S_K
Klaus_S_K Posts: 10
Hi
Looks like there is some kind of error with the usage data
Lots of application data, but almost no usage data?
Is that correct or is it an error?
  • Zyxel_Melen
    Zyxel_Melen Posts: 1,142
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi @Klaus_S_K,
    Which firmware version is your SCR running? If it is not V1.00(ACGN.2), please help to upgrade to this latest firmware. It has fixed some traffic-accurate problems.
    Here's the release note:
    If the problem still occurs when running V1.00(ACGN.2), please help to enable Zyxel support for me to check.
    The Zyxel support path is Help (On the top right) > Support Request > Zyxel support Access to enable and save.
    Melen
  • Klaus_S_K
    Klaus_S_K Posts: 10
    For the moment i have traffic mangement disabled. I just enabled it again, so we can check data comparison in 24 hours from now. I will get back tomorrow with an update. Have enabled suppport access for you
  • Klaus_S_K
    Klaus_S_K Posts: 10
    Hi
    Same problem today, also on the nebula webpage:
  • Zyxel_Melen
    Hi @Klaus_S_K,
    Thanks for your feedback and the privilege.
    May I know if the latest screenshot is from the client "Lukas PC"?
    In the meanwhile, I will help to check with our engineer to find out what might cause this problem.
    Additionally, we might need your help to provide a remote PC to access SCR50AXE. I will send the request and detailed information to you by private message.
    Melen
  • Klaus_S_K
    Klaus_S_K Posts: 10
    The client name is Sony TV
    Regards
  • Klaus_S_K
    Klaus_S_K Posts: 10
    Hi
    Have to disable traffic management for now, because my boys have to much lag playing online, and i can not get them added to passtrough the app filter.
    Im still available for help and remote access if needed
    Regards
Nebula Tips & Tricks
