FWA510 loses PIN on reboot
Every time I reboot my FWA510 the PIN for my SIM-card is lost and I have to logon to the router and re-enter the PIN. Does anyone have suggestions as to how I get it to remember the PIN?
At the screen where I enter the PIN, it states, that the PIN is automaticly saved in the device, but I clearly doesn't.
Hello @Digit4800
Welcome to the forum.
Are you able to say what version of firmware is in your FWA510 please?
Kind regards, Tony
Hi @tonygibbs16
The firmware-version is V1.15(ACGD.3)C0 (Latest)
Did you make any progress on this problem? I have the same issue. Firmware version is: V1.15(ACGD.3)C0
@Vertimart_TD: Not really😐️ I ended up disabling the PIN-request on the SIM.
I have the same problem with my brand new FWA510 on which i upgraded firmware to V1.18(ACGD.5)C0.
Will there be a solution? I don't want to disable the PIN on the SIM.
Hi @Zyxel_Melen,
Then after reboot:
Hi @rephlex,
Thanks for sharing. I'm checking with our engineer and I'll keep you posted.
Zyxel Melen0 -
Hi @rephlex,
You have to rekey the PIN code after rebooting is the behavior when you enable PIN protection. Since that, you can disable PIN protection to avoid rekey PIN code after rebooting.
Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
