USG20-VPN Crash
USG20-VPN and USG20W-VPN have been renamed to FLEX50 and FLEX50W respectively.
All USG 20-VPN Devices (more then 10) after issue can't update firmware to any version. After 5 minutes happends nothing. Tried update manually, via cloud update, via ftp, it doesn't work
Then your firewall has already been accessed and " edited ". Make sure you have a backup of your configuration and restart it from standby firmware. Then you can update it again. (With a bit of bad luck, you will have to reset it and reload the config after the restart to standby firmware).
Rebooted with standbay FW, trying to update with FLEX50 firmware, and again nothing happends
File uploads, then page refreshes instantly, and shows logo screen again0 -
I can't reset devices manually, there are in many miles from me
I have got the same problems. Did you find a solution ?
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
