VPN 50 login issue
bigjimmylaw
in Security
I received the email today about the firmware upgrade. I cannot get logged into either of my devices so that I can perform this. I am getting a 504 gateway timeout after I click login. Any ideas?
you need to download new firmware unplug WAN reboot and update
Disconnect WAN and reboot. Then upgrade.
Hi @bigjimmylaw
Thanks for reporting this case to us. As mentioned by PeterUK and RSaull, we suggest the following steps:
Step 1: Disconnect the WAN port connection and reboot your device.
Step 2: Access the device's Web-GUI using the LAN port.
Step 3: Update the firmware to our latest version, V5.36P2.
You can download the firmware from this link:
Thank you.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
