NR7101 ABUV8
Nebula version is not available yet!
Modifications in 1.00(ABUV.8)C0
[Know defects]
1. [Internal Issue#43] DHCPv6 relay function fails
[Feature Enhancement/Configuration Changing]
1. Change version from 1.00(ABUV.8)b3 to 1.00(ABUV.8)C0
[Fixed Defects]
N/A
Modifications in 1.00(ABUV.8)b3
[Know defects]
N/A
[Fixed Defects]
1. [eITS Ticket # 230300772] No dual SIM failover happened
2. [Vulnerability] Potential buffer overflow in CGI
3. [Internal Issue# 20725] Two APNs are random used simultaneously even the dual APN feature is not
enabled under auto APN mode.
4. [Internal Issue# 30536] Special character WiFi SSID cause Scan QR code malfunction.
5. [Internal Issue# 30647] could be upgraded to other project FW directly
6. [Internal Issue# 31722] Cellular info in Web GUI is not correct for SA NR CA mode
7. [Internal Issue# 31761] DUT can't get correct DNS server information from ISP (Customer Version)
8. [Internal Issue# 31762] DUT can't get correct DNS server information from ISP(Generic Version)
9. [Internal Issue# 31794] NR PCC has no Phy Cell ID info. under EN-DC RAT
10. [Internal Issue# 31795] Signal Information Table has wrong information.
11. [Internal Issue# 31872] DUT happened "Sending discover"
12. [Internal Issue# 34860] RM fail via Cellular WAN2/3 under 5G-SA with IPPT/Router mode
13. [Internal Issue# 35676] GUI will hang after changing RAT then select part of Cellular related options.
14. [Internal Issue# 35909] 3G shouldn't be included in Preferred Access Technology by default
15. [Internal Issue# 35857] Switch mode between IPPT and Router, will cause DUT to disconnect, reboot
can recover.
16. [Customer’s Issue] Change to syslog size from 100kib to 1000
17. [Customer’s Issue] Changing operation mode from IPPT to Router mode brings NR7101 offline
10/37
www.Zyxel.com
Zyxel Confidential
18. [Customer’s Issue] DHCP Server does not assign IP addresses on untagged Bridge1 out of
195.3.85.243-195.3.85.246 pool it is configured in router mode
19. [Customer’s Issue] extension of the "Trust Domain" ACL with this ULA
network: fda1:3fb1:0:102:0:0:0:0/64
20. [Customer’s Issue] TR-069 SPVs InternetGatewayDevice.Cellular.NetworkMonitorEnabled return 9002.
21. [Customer’s Issue] reboot router via SMS txt message feature request
Modifications in 1.00(ABUV.8)b2
[Know defects]
1. The page “Agent ContorllerMQTT” change to “MQTT Agent Controller”
[Fixed Defects]
22. [eITS Ticket # 220900596] Fix infinite loop in the ping of diagnostic when input IPv6 addresses.
23. [eITS Ticket # 221200524] USP Boot when changing broker
24. [eITS Ticket # 221201311] WebGUI Missing cellular info
25. [eITS Ticket # 230100554] Baseband not shown without SIM card
26. [eITS Ticket # 230101369] APN change causing LAN disconnection
27. [eITS Ticket # 230101370] certificate dates
28. [eITS Ticket # 230200494] Disabling NAT by TR-069 does not work immediately; a reboot is needed
29. [Internal Issue #34490] Web GUI is always loading
30. [Internal Issue #34526] There is no APN column of APN#4 in SIM 1 / SIM 2.
31. [Internal Issue #30639] CM detected Device status as CREG_REGISTERED_ROAMING while
registered with EHPLMN in SIM
32. [Customer Issue] Public Subnet Not Work
33. [Customer Issue] Set TR-471 default server
34. [Customer Issue] Remote-Access on further APNs2-4
35. [Customer Issue] add the ACL "Trust Domain" and Activation of Maintenance WiFi per default
36. [Customer Issue] Manual band locking will result in device losing connectivity. Reboot will restore
connectivity
37. [Customer Issue] Device fail to display in GUI and CLI
11/37
Modifications in 1.00(ABUV.8)b1
[Know defects]
1. Add TR-471 test item in Diagnostic page
2. Add new feature that can set different APN in in different SIM slots for Dual SIM.
[Fixed Defects]
1. [eITS Ticket # 220900182] Device.SoftwareModules.InstallDU() doesn't handle https and
command-injection issue
2. [eITS Ticket # 221000453] NTP Client
3. [eITS Ticket # 221001636] USP: Map Bandwidth ID from driver to actual BW in MHz
4. [eITS Ticket # 221001646] USP: Unnecessary parameter RSSI
5. [eITS Ticket # 221001652] UDP: Add eNBID/siteid to datamodell
6. [eITS Ticket # 221100294] obuspa client restarts during
7. [eITS Ticket # 221101479] Set "Device.Cellular.X_ZYXEL_Refresh_Interval" to an empty value
disconnects cellular WAN
8. [eITS Ticket # 221100532] USP: Issues with ExecutionUnit.{i}.SetRequestedState() and/or
ExecutionUnit.{i}.Status
9. [eITS Ticket # 221200525] Add LAN-client OUI to data-model
10. [eITS Ticket # 221200526] Band numerical value
11. [Internal Issue #26006] UE CALL Trace and then go into "LTE_MODULE_HW_RESET" status loop
cause UE connect fail
12. [Internal Issue #26483] UE continue reboot by itself for CALL TRACE
13. [Internal Issue #28638] The setting(MGMT Services and Trust Domain) of Remote Management can't
be saved after we upload the backup configuration.
14. [Internal Issue #28750] Backup/Restore function doesn't include TR-369 configuration setting
15. [Customer’s Requirements] Change to New Certificate1
Doesn't seem to be on the download page yet:
Is there a corresponding version for Nebula somewhere?
Any idea what's fixed?
[Know defects]
[Fixed Defects]
N/A
[Know defects]
N/A
[Fixed Defects]
can recover.
10/37
www.Zyxel.com
Zyxel Confidential
[Know defects]
[Fixed Defects]
connectivity
11/37
[Know defects]
[Fixed Defects]
15. [Customer’s Requirements] Change to New Certificate1 -
Wow, thanks, I'll try it when I get home. R13 modem firmware soon?
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
