Disconnecting from SSLVPN after 30seconds
Hi Nathanoum
I have also had this problem with HP devices, the reason was the HP LAN / WLAN / WWAN Switching UWP service.
When the service is stopped, it worked for me.
Good luck0 -
Thank you, the service is desactived on my device.
Did the monitor log show anything when the SSL VPN disconnected?
Have you tried another PC? I would like to know if only happen on a specific PC or if it's a general issue.0 -
Nothing is displayed when disconnecting.
Yes it works on two other computers.
Computer model affected: HP Elitebook 840 G90 -
What's your PC windows version? and I would like to check SecuExtender log
Please collect the secuExtender log on the Windows PC
C:\SecuExtenderHelper.log
C:\Users[windows account]\SecuExtender.logMoreover, you may check if the service SecuExtender Helper is running when the issue happens, thanks
You can also check if the account reaches the max number of simultaneous logons. Object > User/Group > Settings > Limit the number of simultaneous logons for access account. Or the SSL VPN IP address is not enough for assigning to this PC.
I tried resetting the network card settings, uninstalling and reinstalling the program. It still does not work.
Please help me!
That look likes DNS resolution issue if you were able to connect at start.
When you initiate connection check if DNS server of your network card is properly replaced by DNS server of your SSL VPN.
Did you use the same network to initiate the VPN connection on all computers ? The SSL VPN Client seem not working with IPv6 instead of IPSec Client.
The DNS of the virtual network card is correct, that of the Wi-Fi card remains that of the network on which I am connected,
Yes same network on two other computers 1x LAN and 1x WLAN. always the same login.
Also try to deactivate the IPV6 protocols of the two cards, does not change anything.0
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 685 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 504 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 112 Security Highlight
