Recover Missing NAS Shared Folder (NAS changed its status to 'Lost')
Christos_Koziaris
Christos_Koziaris Posts: 1 image  Freshman Member
edited September 2022 in Personal Cloud Storage
Hi
On a NAS326, a Shared Folder disappeared and changed its status to 'Lost'.
As I cannot edit the entry of the Folder, how this can be recovered?
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Do you have two volumes? If yes, are they both healthy?
  • nmoon88
    nmoon88 Posts: 7 image  Freshman Member
    I am having exactly the same problem and need help with this
  • PKA76
    PKA76 Posts: 1
    I have the sam problem. After reset a can’t change the “Lost” status to “Normal”
    Do you have some solution for it?
    Thanks a lot!
  • Mijzelf
    I think a share is 'Lost' when the shares database says there should be a share, but the corresponding subdirectory on the data volume isn't there.
    A subdirectory can disappear on a hard reset due to a filesystem corruption. In that case it might be in the lost+found directory, where the filesystem dumps all files which doesn't seem to have a parent directory.
    Login over ssh, and execute
    su
    cd /i-data/sysvol/lost+found
    ls
    If ls shows anything, that could be your lost data.
