Nebula Pro Trial Pack License Not Working
aduw1ng
aduw1ng Posts: 2 image  Freshman Member
I activated the Nebula Pro Trial pack 30 day license. However there is a banner on top saying I am using the Base pack.
How do I apply the trial license?
Thank you.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,589 image  Zyxel Employee
    Hi @Lohkamp
    You see the banner is because enable the Nebula Pro pack trial will not change your organization type, if you mentioned the pro trial license is in the License & Inventory > trial tab.
    Although the organization type is base pack, you can still use all of the features including those that require the organization type to be PLUS/PRO pack.
    Zyxel Melen
  • Zyxel_Melen
    Hi @aduw1ng,
    When the Nebula Pro Pack trial is activated, you will see your organization is using the Base pack.
    It is a normal behavior, you could check the Pro Pack trial status in Organization > License & Inventory > trial.
    Hope it helps.
    Zyxel Melen
  • Lohkamp
    Lohkamp Posts: 31 image  Freshman Member
    We have the same problem - activated the pro trial license for a new customer but it shows (in German) "in Bearbeitung" (= in processing) for several days now.
  • Zyxel_Melen
    Hi @Lohkamp
    Zyxel Melen
  • Lohkamp
    Ok, thank you very much.
Nebula Tips & Tricks
