External Captive Portal (OPNsense) in Nebula possible?
baba
baba Posts: 280  Master Member
is an external captive portal from OPNsense possible with Nebula, NWA210AX access points and USG Flex 200 as firewall?
How to configure in Nebula?
Thanks!
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,242  Zyxel Employee
    HI @baba ,
    We provide the way to configure external captive portal for a SSID on Nebula at this FAQ.
    Please refer to the guide to implement the configuration.
    Zyxel_Judy
  • baba
    Hi @Zyxel_JudyH ,
    i want to use a external captive portal ( https://docs.opnsense.org/manual/captiveportal.html ) and not modify and host the zyxel html files.
    Thank you!
  • Zyxel_Judy
    Hi @baba ,
    You can design the captive portal on OPNsense by yourself, and then configure the URL here.
    In case need to configure the parameters required for your external captive portal's URL, please go to your community inbox to get the attachment includes the attribute for Nebula using external captive portal.
    Zyxel_Judy
Nebula Tips & Tricks
