Zyxel NBG6817 U-boot Recovery
I have a couple of APs that were flushed with a custom openwrt build for FB-Soma-mesh Project that I would like to recover and flash with a newer openwrt/zyxel firmware... I currently do not have root password but I do have serial access... The failsafe mode has been disable and also tftp boot prompt by pressing the wps button on power on... Attached is the output from serial port for both 'printenv' in u-boot,..... Is it possible to update the U-boot and flash a a new firmware?
Hello @Ortiz
Welcome to the forum.
The instructions at https://openwrt.org/docs/guide-user/troubleshooting/root_password_reset might help you.
There is also a dedicated Openwrt page for NBG6817 at https://openwrt.org/toh/zyxel/nbg6817
Kind regards,
Tony
Hi Tony,
Thanks for the share, My issue is that there is no failsafe mode, seems like it was disabled on that bild as per the serial output I shared.... I only access u-boot menu during boot
Hi @Ortiz
You're welcome.
There is mention of Poky in your logs, which is the Yocto Project Reference Distribution, and it suggests that it is version 2.7 (warrior), which has some documentation at https://docs.yoctoproject.org/2.7/mega-manual/mega-manual.html
But I haven't found much more yet.
Kind regards,
Tony
3 hrs into the document, nothing useful of getting failsafe or recovery active... Any ideas of how to upgrade the bootloader
Hello @Ortiz
This looks like a way of upgrading U-boot but not the Poky.
https://u-boot.readthedocs.io/en/latest/usage/dfu.html
And this might also help
if you can get the Zyxel firmware.
This link seems to have some old Zyxel firmware from 2017 https://drivers.softpedia.com/get/Router-Switch-Access-Point/Zyxel/ZyXEL-ARMOR-Z2-NBG6817-Router-Firmware-1-00-ABCS-3-C0.shtml
Although this is not the latest Zyxel firmware according to
Once you have installed that Zyxel firmware successfully then you could try to install the latest release of Openwrt. See https://openwrt.org/docs/guide-user/installation/generic.flashing using the firmware update option of the Zyxel firmware.
Kind regards Tony
Seems like the OS was based of the Lede version, I was able to flash lede v 17.0.1....but now I can't move to openwrt newer versions... I have to move to 18, but seems like something is a miss... Keeps rebooting during kernel initialization
Also I was able able to compile/download a working updated u-boot... Might it be that the u-boot is of an older v?
Hi @Ortiz
Maybe…It is dated 2017 in your logs. But it might still work enough to allow you to load Zyxel firmware.
This might help too, see https://forum.openwrt.org/t/solved-zyxel-nbg6817-flashing-from-oem/768 and https://openwrt.org/docs/techref/bootloader/uboot
Kind regards,
Tony
- 601 USG FLEX H Series
- 480 News and Release
