Assigning private Vlans to zyxel AP SSID
Hi @Tazman ,
You can refer to this FAQ to configure to separate SSIDs between Zyxel APs.
And then, go to Configure > Access point > SSID advanced setting to assign the VLAN ID for each SSID:
Please make sure that the gateway and switch(es) have configured the corresponding VLAN interface.
Zyxel_Judy
This answer makes it seem like it’s not possible. A private vlan is a vlan within a vlan, so I’d be real surprised if just tagging a vlan is enough.
Hi @Tazman ,
From you description, we assume that your goal is to avoid AP_1 and the wireless clients connect to AP_1 (connect to port 7) to communicate to AP_2 and the wireless clients connect to AP_2 (connect to port 8) although all of them are belong to VLAN10.
If this is the case, after doing the configuration on the previous post, you may configure port isolation on Switch to achieve the goal.
Steps:
1. Advance application > VLAN > VLAN configuration > VLAN port setup
2. Check the "Isolation" box where the APs are connected, and click "Apply" button.Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
