WAP6807 Firmware
Msanchez
Msanchez Posts: 1 image  Freshman Member
edited August 2023 in Home Router
Good afternoon, I have a problem with the WAP6807, I bought a batch of these devices with version 1.00(ABTB.1)b12 where I could make a configuration file (backup) to apply it to other devices obviously with the same version, now I'm having A problem because I received a new batch with version 1.00(ABTB.2)b20_C0 to which I made a backup file with a peer device, but this configuration file is not replicated to other WAPs, only to itself.
even with a factory backup file, it doesn't replicate from one WAP to another, so I read in the patches a higher version encrypted the configuration file, I don't know if I'll have to see that.
I really want to apply these changes to other WAPs to be able to monitor them better.
these changes only change the HTTP port which by default is 80 to a port like 45600
If anyone knows where I can get version 100.(ABTB1)b12?
It is an image where it shows the changes of this version
  • Liba
    Liba Posts: 218 image  Master Member
    First Comment First Answer Third Anniversary
    I recommend that you can contact your ISP or retail store for the help.
