SSL VPN
Ricky
Ricky Posts: 3  Freshman Member
edited April 2021 in Security
I have set up SSL VPN and as a user I can connect. However, the client is not getting a IP address from the Zyxel 110. the Firewall LAN1 IP scope is 192.168.11.1 - .254 , with a DHCP range of 192.168.11.10 - .254. When a SSL VPN client connects it shows connected, how the IP address given is 192.168.11.0 .... and nothing from the DHCP range. I am using SSL VPN client v4.0.3.0 and the firmware on the Firewall is v.4.33 (AAAA.0).
  • Ricky
    Disregard, I figured out the issue. The SSL VPN requires an assigned IP pool that is not on the local LAN1 scope.   I created a Virtual Scope under LAN1 and then added that as a RANGE in Object/Addresses.  once that was done I connected back the the SSLVPN and was handed out an IP within the Virtual Scope and life was good.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,388  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @Ricky
    The VPN (SSL VPN/L2TP VPN) pool can’t overlap to other interfaces, otherwise the traffic unable pass into VPN tunnel successfully.
    It’s good hard you found the reason of it. :+1:
  • DACataldo
    DACataldo Posts: 11  Freshman Member
    edited June 2023
    I have a similar issue where the vpn connects and i get 192.168.201.100 and the server is 192.168.200.1 but I keep getting an ACCESS BLOCK in the log when 201.100 tries to talk to 200.1. What is the issue, please?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 944  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @DACataldo ,
    Greeting Forum, the default Network Extension Local IP is also 192.168.200.1. It should not overlap with your local subnet.
    Please kindly change IP from 192.168.200.1 to anther one. Thanks
  • DACataldo
    Thank you for your reply. My global setting looks like yours. My subnet is 201 not 200 in the VPN config - do you mean like this?
    Thank you so much!
  • Zyxel_Kevin
    Hi @DACataldo ,
    Yes , I means replace the global extension IP from 192.168.200.1 to 192.168.X.X which is not used in your subnet.
    Address 192.168.200.1 is the same as your DNS server
  • DACataldo
    edited June 2023
    Thank you for helping. Now it gives me access to the WINS server (10.10.1.14) and also the internet. Still blocking everything else on the 10.10.1.0/24 network though. They get blocked by the default rule. What rule am I missing? Perhaps I should pay for Zycel advice? What is the correct Zyxel phone number that I am supposed to call to pay for someone to fix this for me? Thank you.
  • Zyxel_Kevin
    Hi @DACataldo ,
    Please kindly check :
    1)You have correct Zone for SSL VPN settings
    2)You have default policy From SSLVPN zone to any
    If the issue persist we can have remote session at 08:00~17:00 (UTC+8) . Thank you
  • DACataldo
    edited June 2023
    Thank you again for your response! Here is my SSL VPN policy and below that are my security policies:
    It seems to have access to a couple IP addresses on 10.10.1.0/24 and no access to most of that network. And I am using SecuExtender 4.0.4.0 - should I be using 4.0.3.0?
    Thank you again!
    Dave
  • Zyxel_Kevin
    Hi @DACataldo ,
    Could you provide remote GUI access for us.
    I sent you my public IP by private message. You may only allow those for access.
