Unmanaged Switch MG105 - ping ok, internet ko
2»
    PeterUK Posts: 4,268 image  Guru Member
    edited June 2023
    And now you can TCP to me suggests a PC/Mac problem or you can run Wireshark
    or
    tcping64 1.1.1.1 80
    tcping64 8.8.8.8 443
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    edited June 2023
    Hi @Zotme,
    You can also open some websites when you run Wireshark. This is used to capture the traffic to clarify the problem.
    Also, could you try ping 168.95.1.1 and ping 168.95.1.1 -l 1500 when the client is connecting with issue MG-105? Since the previous result, I want to verify if the switch can forward 1514-byte packets.
    Zyxel Melen
    Maybe your NIC is set with jumbo packet bigger then 1514?
  • Zotme
    Zotme Posts: 8
    MG-105 NO ok
    tcping64 1.1.1.1 80
    Probing 1.1.1.1:80/tcp - Port is open - time=10.134ms
    Probing 1.1.1.1:80/tcp - Port is open - time=10.277ms
    Probing 1.1.1.1:80/tcp - Port is open - time=10.261ms
    Probing 1.1.1.1:80/tcp - Port is open - time=10.179ms
    Ping statistics for 1.1.1.1:80
    4 probes sent.
    4 successful, 0 failed. (0.00% fail)
    Approximate trip times in milli-seconds:
    Minimum = 10.134ms, Maximum = 10.277ms, Average = 10.213ms
    Probing 8.8.8.8:443/tcp - Port is open - time=9.767ms
    Probing 8.8.8.8:443/tcp - Port is open - time=10.103ms
    Probing 8.8.8.8:443/tcp - Port is open - time=9.858ms
    Probing 8.8.8.8:443/tcp - Port is open - time=9.992ms
    Ping statistics for 8.8.8.8:443
    4 probes sent.
    Minimum = 9.767ms, Maximum = 10.103ms, Average = 9.930ms
    ping 168.95.1.1
    Esecuzione di Ping 168.95.1.1 con 32 byte di dati:
    Risposta da 168.95.1.1: byte=32 durata=285ms TTL=53
    Statistiche Ping per 168.95.1.1:
    Pacchetti: Trasmessi = 4, Ricevuti = 4,
    Persi = 0 (0% persi),
    Tempo approssimativo percorsi andata/ritorno in millisecondi:
    Minimo = 285ms, Massimo = 285ms, Medio = 285ms
    Esecuzione di Ping 168.95.1.1 con 1500 byte di dati:
    Richiesta scaduta.
    Richiesta scaduta.
    Richiesta scaduta.
    Richiesta scaduta.
    Pacchetti: Trasmessi = 4, Ricevuti = 0,
    Persi = 4 (100% persi),
    MG-105 OK
    Risposta da 168.95.1.1: byte=1500 durata=285ms TTL=53
    Risposta da 168.95.1.1: byte=1500 durata=286ms TTL=53
    Minimo = 285ms, Massimo = 286ms, Medio = 285ms
    I don't know how to use Wireshark, sorry.
    So what happens if you swap switches?
  • Zotme
    Zotme Posts: 8
    What…. as I said "I've two switch MG-105, in the same configuration router-pc-cables, one switch works the other no…".
    edited June 2023
    Yes nothing makes sense as to why one works and the other does not so swap them over to see what happens.
  • Zyxel_Melen
    edited June 2023
    Hi @Zotme,
    Thanks for the information. Please reference this RMA link to submit an RMA request for the issue MG-105.
    Zyxel Melen
