AP & multi-SSDi
Hi @zarital
If you're looking to create multiple SSIDs for each access point, the NWA50AX does support this functionality.
In standalone mode, AP offers the capability to apply 8 SSID profiles per radio slot. This means that if you utilize all available slots, you can have a maximum of 16 SSIDs simultaneously broadcasted (8 on the 2.4GHz band and 8 on the 5GHz band). It's important to note that each SSID will only be broadcasted on its respective radio band. However, if your requirement is to broadcast all the configured SSIDs in both the 2.4GHz and 5GHz bands, the maximum number of SSIDs that can be broadcasted simultaneously would be 8.
In Nebula cloud mode, AP allows for the configuration of up to 8 SSIDs.
You can configure each SSID with different security options and other advanced settings. Here are the guidance for creating SSIDs in two different AP management modes:
- For Standalone mode: How to create an SSID on Standalone mode — Zyxel Community
- For Nebula cloud mode: [Nebula] How to create SSID and set security? — Zyxel Community
Kay
Hi @zarital
Kay
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
