It does not display the web correctly in 2k resolution
  • ikubuf
    ikubuf Posts: 143  Ally Member
    Are you using Google web browser?
    you can ty to clean the browser cache.
    You can try with developer tools on Chrome by pressing Ctrl+Shift+I
    And click the disable cache and refresh the pages.
  • ikubuf
  • Jarose78
    Jarose78 Posts: 2
    Thank you, it works, but when I close the developer tools, it doesn't work again
