Adding new volume question
VnR
VnR Posts: 1 image  Freshman Member
edited June 2023 in Personal Cloud Storage
Hi all,
Apologies if this question has been asked before.
I currently have 1 Hard disk installed on Raid (Basic) that is nearly full. I will install 2 new Hard drives on raid 5.
What is the best way to set it up so i can move all the files to the new volume, then add the old harddrive to the new diskgroup/volume?
Thanks in Advance
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    To copy a file, it is recommended to first back up the file to your laptop or any other storage location where you can safely store your data.
    Afterward, create a new volume and transfer the data to the disk.
