which file do I have to upload for updating the LTE5398-M904 router firmware?
Sfarfall
technically what are the steps to follow? If I read the instructions:
"Default Settings in Firmware
- Refer to the *.rom in the fw release package.
- readable default configuration.
- *.config define the default value of writable parameters, *.predef define the default value of read only parameters.
- Please use the website http://jsoneditoronline.org/ to open the *.config and *predef files.
I don't understand because I downloaded the new firmware (v.3) but I see only a .bin file.
Thank you for help
The .bin file is a straight forward download using the standard HTTP GUI. No need to worry more than that…
V1.00(ABQV.3)C0 seems to be the latest firmware.
Thanks @JeanFrancois !
- 588 USG FLEX H Series
- 476 News and Release
