Virtual LAN interface in Nebula ATP200
Hi @AHGJSoree
Thanks for your inquiry. Currently, the nebula doesn't support the virtual interface feature. We will shift your post to Nebula ideas for further evaluation. Thanks.
Hi @AHGJSoree
Could you please explain why you intend to configure a virtual interface on the LAN interface? Is there a specific purpose or goal you have in mind? Thank you.
We are currently changing our subnet from 192.168.220.0/24 to 172.16.127.0/24. We are using an old USG310 still so adding an extra IP address as a gateway is an easy way. The USG310 then acts as a default gateway with both subnets. This is an easy quick approach.
Jeroen
- 441 Beta Program
- 293 Service & License
