How to set up a Ras542 with 4 pieces 16GB
dj54dan
dj54dan Posts: 4 image  Freshman Member
Want to see the 4 pieces 16GB as a device from a win10 PC.
Have made 3 volume but how did you set it up to see them from a win10 PC
How can I see all the hard drives in a device /volume on a win 10 PC.
Can you help me ?
  • Mijzelf
    Mijzelf Posts: 3,034 image  Guru Member
    You have to create at least one share on each volume. Those shares are visible in Windows.
  • dj54dan
    edited June 2023
    Thanks for replay
    I have entered the different volumen in Shared Folders.
    But how can I see them as on drivee in win10 PC
    Can you help me ?
    But I want all volume as one drive in win10 PC, is this possible? How to do it?
    Is it possible to merge volume 1, 2 & 3 together to one drive in win10 PC
    Can you help me?
  • Mijzelf
    No.
  • dj54dan
    Can I use the StableBit Drivepool program?
    Anyone that have experience with this program?
    Have downloaded a test version but the program does not recognize the RAS drives, they do not see them
    Do I have to live with 3 different drive​ from RAS542?
    No other solutions to put these drive together into one?
