ZYXEL USG FLEX 100W and Adding AP
What upload bandwidth do you have with the FLEX 100W? 4K needs a bit
Internet 290 Mbps down/23 Mbps up
I have several 4K Cams and all work fine through the 100W, it's just this one that chokes when going through my Netgear EX3700 extender.
Not Cat5 to extender it's working via wifi connection…..
Suggestions??
I can't find this in the US but what about Zyxel
WiFi 6 AX1800 Wireless Gigabit Access Point | Mesh, Seamless Roaming,
& MU-MIMO | WPA3-PSK Security | Cloud, App or Direct Management |
POE+ or AC Powered | AC Adapter Included | NWA50AX ??0 -
Yes 4k Cams
But wouldn't I need an extender that works in AP mode?
you might not have enough bandwidth
On my USG60W you can't have the built in wifi as root AP to run a repeater AP to it you should be able to run a extender but the bandwidth might not be enough.
You can get a AP and run by Ethernet either Controller-managed or Standalone
Along with getting a PoE+ injector
Wierd….the manual talks about Zmesh…..don't understand why I can't setup a mesh……
Guess Asus just makes it easy…..Get a good router add a cheap Asus router and turn on AiMesh and they connect sleeplessly and continue working…..roaming is so good.
I purchase this replacement FW because it supposedly has a mesh capability but good luck finding out how to do it……
What am I missing?
But I have 4 other 4k cams on the same Flex 100 and they stream just fine……locally and via internet….
I can see the extender gag when it's being put to work….ping times 1ms then I ask it to do a simple task like go to another part of setup such as network and I lose connection…..then it slowly comes back with high ping times then the pings go back to 1ms and I can do something else, it's an AC750 so if I move to a 1800 I'm thinking that will handle the traffic?
What am I missing?
just not with the built in wifi
- 602 USG FLEX H Series
- 481 News and Release
