NR7101 factory defaults reset via SSH
jgr
Can I do factory defaults reset via SSH?
Router is mounted in a mast, 18m above the ground, so it is not so easy to press reset button.
BR
You can do a factory reset in GUI. Maintenance, Backup/restore, scroll down to "Back to Factory Default Settings" and hit yellow Reset button...... Note! You need password printed on the label on your unit after a factory reset to log in again!
- 588 USG FLEX H Series
- 476 News and Release
