Is there any Zyxel ONT that I can use a VPN on it?
Hello. I want to use a VPN on an ONT (I have PMG5617T20B2 right now), which of Zyxel products has this posibility?
Is there any chance that in near future Zyxel release a firmware update for PMG5617T20B2 with VPN capability?
Hello @mhasamah24
Welcome to the forum.
I don't think that you will find an ONT with VPN built in, as an ONT is more an OSI-RM layer 1 (physical) and layer 2 (data-link layer) device.
An ONT would solely do conversions between optical and electrical Ethernet with some management as well.
VPN is more at OSI-RM layer 3 (Router) layer functionality, and so would pass through an ONT.
So VPN functionality would be built into a Router, or be software/hardware on another host that the ONT would pass straight-through.
I hope that this is helpful.
Kind regards,
Tony
Thanks for your answer🌹
Do you mean that I can use a Router after ONT to have this feature?
If not, what's your suggestion to nail this? Or this means that it's impossible?
Hello @mhasamah24
You are welcome.
Yes, I am saying that you would need to use a router after an ONT, on the customer premises side, and then run the VPN on the router or on a computer connected to the router on the customer local area network.
Kind regards,
Tony
I hope I don't make you tired with my questions.
The usual Routers which used for ADSL are compatible with ONT or I should buy a specific Router?
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
