[NEBULA] Disable auto provision
Triceratops
I want to stop the function when configuring APs before deploying.
Is it possible to disable-autoprovisioning?
hhmmm... Isn't that equivalent to limiting nebula control center as a web monitoring tool only?0
@Triceratops
Nebula is designed for cloud network management, it's unreasonable to disable auto-provisioning.
Just like @Iwannaquitthegym said, if the auto-provisioning is disabled, NCC will be a remote monitor not a control center.
If you want to setup the configuration before deploying, you can register the device and do the configuration without device connecting to NCC.0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
